Why wont it get off of the "gameboy" screen?
My gameboy is charged, and turns on and it goes to the 'gameboy' screen but it wont leave that screen. HELP!! what do i do? how can i get it so i can play games on it?
If you're turning it on while there's a cartridge in the slot, then it means it's not reading the game, and is acting as if there's nothing inserted (whereas if there's no game inserted, it'll sit at the Game Boy screen since there's nothing to read). Most likely in this case it's just a matter of cleaning the contacts on the Game Boy Advance cartridge, preferably with high-grade rubbing alcohol (I'd recommend nothing lower than 97%).
Have you tried staring it up with only one game, or have you tried a few?
このアンサーは役に立ちましたか?
Hi! I’m also having this problem and I’ve tried them on multiple games- should I clean the cartridges as well?
Whooo!!! I bought a Gameboy Adance SP for $20 and I was beginning to think it was defective because it was getting stuck on the Gameboy startup screen. Cleaned the contacts with an alcohol swab, blew in it a bit and voila!
I wonder if anyone can help, my gameboy says Nintendo when a game is interested then shortly after it goes blank. If anyone has any ideas please let me know. All contacts have been cleaned. Thank you
Thx it helped
Ahah, I’m even surprised that this console is still alive and that you have it in your hands :)
I don’t want to upset you, but the chance that you can fix it is very low. Because there is pretty old technology and even the master could not fix the screen, so you have two solutions. You can spend a lot of money and buy limited consoles or install an emulator with various games from https://romsie.com/roms/gameboy-advance . It seems to me that the second option is much more reasonable. I tried this method and it works great!
このアンサーは役に立ちましたか?
put a game in the Gameboy to get pass that Gameboy startup screen so it will work
このアンサーは役に立ちましたか?
過去 24時間: 29
過去 7 日: 231
過去 30 日: 1,064
今までの合計 57,295
2 件のコメント
Has anybody fixed this problem I really want to play this new Spider-Man game I just got on it
Joseph matthews さんによる
how to fix it would someone explain it to me because i am in the process of buying one
minirosen さんによる
