My screen presses randomly even after a screen replacment
I have replaced my screen due to it being smashed and pressing randomly and it worked for a few days then went odd so they put a new screen on again and now this problem is keep on repeating
Hi
sounds like the glass screen is touching the lcd!
or you have had some water damage!
to the mobo . i wouldn't spend anymore money on it.
Ray
このアンサーは役に立ちましたか?
I could possibly have water damage
It is fine again today so im not really sure what to do
If your screen is acting up (random behaviours - random swiping or random characters etc) and as it's happening on 2 screens, you either have 2 bad screens or:
1. The touch connector ribbon is not connected to the motherboard correctly
2. The touch connector (FPC) on the motherboard might be damaged - remove the screen and inspect it under a good light source
If you obtained the 2 screens from the same place hopefully that's where the problem is and not with the motherboard. I've seen a few third party screens coming out of China that have weak touch connectors. They don't snap / click into the motherboard like they should. The main LCD connectors are fine.
Good luck
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 85
