メインコンテンツにスキップ
1.7GHz デュアルコア Intel Core i5(Turbo Boost使用時最大2.6 GHz)3MB L3キャッシュ
20回答 すべてを表示
Trackpad not working: swollen battery or bad trackpad?
Hi All,
The Trackpad on my mid-2012 11" MacBook Air stopped working. The battery doesn't seem to be losing power. Other than opening up the computer and looking for swelling in the battery is there any easy way to diagnose the cause (i.e., is it a bad trackpad or a bad battery?). I'm hoping to order the right part (trackpad or new battery) before I open the computer up.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
最も参考になった回答
Well this is a no brainer, open it up and look, don’t guess.
MacBook Air 11" Mid 2012下部ケースの交換
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Hi
I would buy a new track pad!
then the battery .
It could also be a dodgy ribbon?
Ray
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks Ray. The pad won't actually click, so I'm guessing it's more likely the pad itself rather than the ribbon. I'm going to try the new pad first and see what happens...
さんによる
check out the battery first. it has a half life, goes bad well before the trackpad.
さんによる
コメントを追加
Does the trackpad have less travel, or a less clear and crisp click? If so, I would go the battery route first. If it does not show these symptoms or just doesn't work at all, take it to an apple store. It is probably the trackpad itself. This can be replaced at home but a trackpad issue could be many different things, so I would take it to an apple store first.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This worked as first aid, now I have time to look around for a replacement battery.
These are spacers (hair elastics) at the near corners of the trackpad to bend the battery out of the way of the trackpad.
Additionally, I left the middle battery retaining screw loose, about 1.5 turns, to allow the battery to bend.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Grant Kester さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 1,773
