メインコンテンツにスキップ
Released in May 2014, the Chromebook 2 features an 11.6" display, Intel Celeron processor, and a 16GB SSD. Identified by model number XE500C12-K01US.
14回答 すべてを表示
Can the charging circuit on the Chromebook xe500c12 be replaced?
The charger died, and in the process of trying to retrofit a charger I seem to have damaged the device. Now that i have a new replacement charger, there is no light when the charger is plugged in, and the device does not charge.
Can the device be fixed? Could it be the charging circuit? Can anything be replaced?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It depends. Perhaps check all the capacitors and other parts for shorts, then it looks like you might have to track down a replacement PMIC of some sort and solder it in. Do you have a picture of the board?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Noel Arnold さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 190
