メインコンテンツにスキップ
テレビのHDMIポートに直接、接続する小型メディアストリーミングデバイス。2014年11月にAmazonから発売されました。最新バージョンには、音声起動リモートが付属しています。
116回答 すべてを表示
締切られた回答
Why won't my fire stick remote work?
Amazon Fire Stick TV Remote
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 10
18 件のコメント
Hi babygizmo361,
If you could provide a few more details about your situation, we would be better equipped to help you out.
For example...
1. What fixes have you tried so far (i.e. Replace batteries or re-pair remote)?
2. Has the remote worked in the past, or is this an out-of-the-box problem?
3. Is the remote visibly damaged (i.e. Is smoke coming out of the remote :))?
Let us know and perhaps the community will have some more specific answers!
Happy fixing
さんによる
Having similar issue. Lost my remote, so bought a new one. All the post I am seeing are to sync it while its at the home screen. But how can you get to the home screen without turning it on first with the remote?
さんによる
fire stick is stuck on registering and wont come off of that screen. how can I fix that
さんによる
I moved the firestick from 1 TV to another & can't get the remote to do anything on the TV i moved it to.
さんによる
I changed the battery but when i try to pair it wont work it use to work when i got it last mouth
さんによる
13件以上のコメントを表示
コメントを追加
17件の回答
最も参考になった回答
If you are sure the batteries are not the problem, it seems some Fire TVs and Fire Sticks forget their remotes so they need to be paired again.
Here is how to pair a remote again.
When you first turn on the Fire Stick, hold down the "HOME" button on the remote for 10-20 seconds, then release.
This will normally pair the remote with the Fire Stick/Fire TV.
If this doesn't work, there is an app for Android and iOS on their app stores that turns your phone/tablet into a remote.
このアンサーは役に立ちましたか?
スコア 7
2 件のコメント:
This really works!!!
さんによる
My fire stick stopped working on two of them. I could get the phone remote working but it did not last. I wish that I did not have to deal with this. Do I buy a new fire stick? I now have two worthless products.
さんによる
コメントを追加
Took a while but I found a way, download the app on playstore for your phone to use as a remote then go to settings using your phone and then click on controllers and blue tooth devices, click on Add new remote then hold down your home button for 10 seconds and it will discover your remote again then use your phone to add that remote by clicking on it and your remote is working again... as long as batteries are good!
このアンサーは役に立ちましたか?
スコア 4
9 件のコメント:
Tried this it actually worked! Thanks, Danny. Be blessed!
さんによる
Thanks! This was the easiest way
さんによる
You are a lifesaver!!!!
さんによる
I use my tablet instead of my phone and thanks for the tip.
さんによる
What app did you download
さんによる
4件以上のコメントを表示
コメントを追加
Hi babygizmo361,
Sorry to hear your remote isn't working. Like David mentioned in the comments, we'll need a little more information about your problem to give you a specific solution. In the mean time, check out the troubleshooting page here for a list of possible causes and solutions.
Happy fixing!
-Kelsea
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I've tried batteries, following instructions for remote issues and neither work
さんによる
I cannot get the remote to power on. I have checked the batteries and bought new ones still no power.
さんによる
Call someone and tell them that it’s not working if they don’t now talk smack and they will give you a new one and a new phone from sprint
さんによる
コメントを追加
Also have a remote not working. Did all the above. Still not working. Turned my iPhone into a remote by downloading the amazon fire stick app. Works like a charm
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Does it have to be a smart tv ?
さんによる
Thank you so much Adele this worked for me
さんによる
コメントを追加
You may need to pair your remote control again to do this hold the home button down for 10 secs ( whilst you are on the home screen ) until you see a notification , I hope this solves the issue .
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Your Firestick is on, and you can see whatever screen is up in the Firestick on your TV....but your remote does not sync. Hold the home button for 30 seconds. Once you have done that, just turn your tv input back to TV, then turn it back to whichever HDMI connection it was on to see Firestick. Your remote should now be working. If not....replace the batteries and try this step again.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
さんによる
コメントを追加
The batteries in my controller were dying so I changed them and then the remote stopped working. It couldn't be paired or anything. I found the old batteries in the trash and put them back in the controller, and it's working again. Perhaps this is a battery issue? We can only use amazon AAA's? It makes sense since amazon is the new ruler of the world.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Only way i got my 2 remotes to work is to remove the back and just roll the batteries in place. No need to remove them. Bad design
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
In order to pair or re-pair your remote, download the Amazon fire stick tv remote app. You can use your phone to navigate the screen so you can pair the remote.
For the person who was stuck on the registration screen… if you press and hold the home button it will restart the fire stick. If this doesn't work unplug the fire stick for 30 - 60 seconds to force a restart.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The remote worked after it was programmed n with the new internet it’s not connecting now
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
why When I press the fire stick remote it does not do bother or work
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I got a fire stick of my man. I got it on my tv and it said network is not connected so I pressed on it but the remote wasn’t working so I got new batteries and it didn’t work again help me
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
when your fire stick remote not working then you should make change your details with the help of its support chat process.
Source: http://www.teqguru.com/amazon-fire-stick...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Yes. Ive put in new batteries on upstairs and downstairs amazon remotes. I keep unplugging & plugging back in TV/Firestick/internet is working fine!
Last night downstairs TV worked but tonight Frozen screen. And Last night upstairs TV worked but tonight Frozen screen. This has been going on for almost 2 weeks. I’ve done everything amazon says to do. No my remote has done this in the past 1 or 2 years I’ve had them but not so consistently/random. Please, who can i call?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Not sure why it's not working
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I tried to program my fire stick remote to my other fire stick tv and now it won't work. How can I set it back to theoriginal
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Won't move after turns on
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 21
今までの合計 120,637
