メインコンテンツにスキップ
2012年3月に発売されたオリジナルiPad2の改良版モデルです。より小さくなったダイプロセッサと再デザインされた内部構造が特長です。修理にはヒート(熱)を当てて、十分注意しながらこじ開けて行く作業が必須です。
73回答 すべてを表示
LCD goes black after replacing the digitizer
Hello all. I came across a problem that had never seen after replacing the digitizer of an iPad 2. The iPad turn on , the Apple logo appears , but after that the screen turns off and no image appears. The iPad still turned on as iTunes recognizes it. Anyone have any idea what might be happening? Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Have you tried to disconnect and remove the digitizer to see if screen works ok ?
From there you can tell if the digitizer causing the problem.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Thanks for answer, but even without the digitizer the issue persists.
さんによる
Would you please check if there is anything missing around the connection on the logic board like capacitor or resistor. Sometimes when you push little to hard some small components gets broken and jumps out of the logic board .
さんによる
Thanks for your time, but the iPad is OK now . A friend took it apart and reassembled it and is now working flawlessly. I don't know if he did anything else , because I wasn't around when he did it, but the most important is that the iPad is working again.
Thanks again.
さんによる
Happy to hear that :)
さんによる
コメントを追加
回答を追加する
Renato Sandre さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 71
