How to replace the HR sensor glass?
I have scratched the heart rate sensor glass and it looks terrible. I need a replacement for it. Can it be done?
Simple answer is yes. All you need to do is replace the chassis.
Just be careful removing the battery cover as they can easily become damaged or cracked during removal so I would suggest removing the battery cover first and if you do crack it you can order a new one or if you get it off cleanly then order a battery cover gasket.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 8
今までの合計 235
