メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The BlackBerry Passport SQW100-1 is a phone that has a physical keyboard and a touchscreen feature in one. Its square-like shape sets the BlackBerry Passport SQW100-1 apart from the other BlackBerry phones.
Security wipe stuck on 97% from 3 days.
It's been more than 30 hours and security wipe on my blackberry passport is still in progress. Initially it was going nice and smooth but after 90% it got really slow.From last 4 hours it's stuck on 98%.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 32
9 件のコメント
Superb.....i waited for 20 hrs & then i thought to look up for solutions
thanks for the guidance
さんによる
I was trying to make security wipe and at d process my battery went low and the phone went off at the process without completing the security wipe pls what should I do? Its showing a yellow warning sign www.bberror.com/bb10-0015
さんによる
Hi Jennifer. Just connect to bb link and choose RELOAD
さんによる
@jenny_sexy
ter a few attempts of rebooting, in the Passport screen you will see a YELLOW triangle with the danger signal (!) inside and the words "www.bberror.com/bb10-0015" and the LED light changes to GREEN...... Hurrah.....
On your computer BB Link shows that you've a Passport connected... Choose the option RELOAD
NOW.... just wait and.... after a few minutes.....Install again all your emails....apps....etc.....
さんによる
you are getting the yellow bb10-015 error message because the device has erased absolutely everything and has no operating system to start it.
use USB to connect it to your BBLink and choose "reload". It will install BB10 for you again.
Takes a while. Enjoy watching the progress bar
さんによる
4件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
OK... long time ago the same happened to my Passport..... follow the steps but.... be patient...
Connect your Passport to computer and OPEN Blackberry Link
PRESS and keep it pressed the Power button...the BB Passport try to reboot for 3 or 4 times and showing the security wipe screen... remember...always pressing power button never release.....the LED light will be always RED
After a few attempts of rebooting, in the Passport screen you will see a YELLOW triangle with the danger signal (!) inside and the words "www.bberror.com/bb10-0015" and the LED light changes to GREEN...... Hurrah.....
このアンサーは役に立ちましたか?
スコア 26
23 件のコメント:
absolutely amazing. still loading. i hope it completes without being interrupted
さんによる
If you follow all the steps I've mentioned above it should take less than 30 minutes. Worked for others...
Worked for you?
さんによる
Thanks for this amazing tip. I was stuck too, trying to reset, and with this method, I could restore. Thanks a lot.
さんによる
It works!!!
1.Open Blackberry Link.
2. Connect the phone with USB to the computer.
3. Press (do not let go) the power button of the phone. Never let go of the button. While pressing it, the phone will reboot 3-4 times. Again, do not let the button go. Then you will see the "YELLOW triangle with the danger signal (!)".
4. Let go of the power buttom and go to tjhe blackberry link desktop app to reload software.
さんによる
Worked for me perfectly. ;) Thank you so much!
さんによる
18件以上のコメントを表示
コメントを追加
Assalamu alikum,
First pull ur batry for 20 second then flash the device with autoloader it work 100% ,
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Kanav さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 43,356
