メインコンテンツにスキップ
Appleが発売したiMac Intel 20インチの修理ガイドならびにサポートです。
892回答 すべてを表示
Install Snow Leopard on 20" iMac without optical drive
I upgraded from Snow Leopard to Mavericks to Yosemite on 20" iMac.
The device is functioning unbearably slow.
I have the snow leopard DVD that came with the computer. But the optical drive is not working on it anymore.
The optical drive is not available as the product now is obsolete.
I attempted to install from recovery partition, it did not work as there seems no recovery options when I boot to that window using Ctrl+R.
Living in an area where I cannot arrange for another apple computer or laptop so I could install OS via another apple drive.
The only option left is to copy the contents of DVD to a USB and install from it.
However, not sure how I can achieve that. Need help!.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Exactly which 20" iMac do you have?
さんによる
コメントを追加
2件の回答
Use an external CD drive from walmart or use disk utlity to make a bootable Usb
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try Command-Option-R instead of the regular Command-R, this should launch Internet Recovery and you'll be able to reinstall Snow Leopard over the internet without the use of a DVD or USB drive.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
fkqrf さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 57
