Why my cd player got stuck after few songs?
I have a Mercedes E 280 CDI from 2007 and i cannot listen more than 3-4 songs on the CD player because it get stuck.If i start again with the first song,it get stuck again at the same way.Thanks
The CD mechanism is probably dirty or misaligned. If the tracks that the lens assembly rides on wear out or lose their lubrication, then the lens can’t travel all along the CD path like it needs to. So then it can only play a certain section of the CD before it gets stuck. You can try a bit of compressed air through the CD loading slot, but most likely the CD player will need to be disassembled in order to do a thorough cleaning and relubrication of the CD mechanism.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 5
過去 30 日: 38
今までの合計 1,440
