メインコンテンツにスキップ
The following information is intended to help service the Nerf N-Strike Elite Strongarm . The Strongarm was released in 2013 by Hasbro under their Nerf brand.
Darts not firing at full capacity
I have 2 strongarms. Sometime ago they were dropped down a flight of carpeted steps. Ever since then, they don't fire at full capacity. Out of the six darts, one or two might work as they should. I have dissassembled it, and nothing looks damaged, yet they still don't work right. Why could this be? Is something out of alignment?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
ベストアンサー
This sounds like an alignment problem. it is more than likely that when dropped the mechanism has shifted and under the pressure of the already tightened screws it has stayed misaligned. i would suggest opening it up carefully following a guide on youtube. just take all the parts out clean them up/check if any are broken or cracked (you may have to use a little bit of thumb pressure to check certain parts for cracks) and if all is good just put it back together again carefully lined up. wd40 is good for cleaning non electric parts due to its water displacement and lubrication qualities.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks! I will probably just replace them, as NERF guns are not terribly expensive. But, your answer is incredibly helpful and hopefully others may use it to bring new life to their NERF battles. I might try to fix them, but I'm not really that attached to them. Thank you so much! :-)
さんによる
コメントを追加
最も参考になった回答
I think it might be because of the fall. The spring might be misaligned.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
How would I realign it?
さんによる
コメントを追加
You might want to look at the air spring...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Michael さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 15
過去 30 日: 25
今までの合計 3,332
