メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
LCD screen is blank on 6 Plus
I've replaced a lot of iPhone screens and just replaced an iPhone 6 Plus screen. After resetting it everything worked properly so I screwed down the bracket. When I went to close the screen I noticed it was blank. I hooked it up to the computer and the touch screen is responsive, just not the LCD. What could be my issue? I've tried two other screens and neither of them will work either.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Is there an image , but no backlight? The image would obviously be very faint with a flashlight against it. And of course you would know which screws go where.
さんによる
Nope, no image.
さんによる
コメントを追加
4件の回答
最も参考になった回答
Here is a guide for you: Why iPhone Won't Turn on after Screen Replacement
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I fixed it. I unplugged the battery and cleaned the connectors with 99% isopropyl alcohol, dried, and gently reconnected it all. Everything works now :)
Edit: I got up this morning and tried it out and now it won't work again :(
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I think it's time to send it to a microsoldering professional. It isn't the backlight filters, because then it would have some kind of image with a light shining on the screen just right. I would guess that it has something to do with the 1.8 volt line on pin 29 of the lcd connector. I could very easily be wrong about that though.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I concur. I am sending one board out at the first of the week and am sending this phone in with it.
さんによる
Good choice. Let us know what the problem was when you get it back.
さんによる
コメントを追加
Could also be that one of the pins bent or broke on the phone itself in the connection on the logic board. Check the pins where the display cables connect to.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
justin epley さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 314
