メインコンテンツにスキップ
2013年11月22日に発売されたMicrosoftの第三世代のXbox ゲームコンソールです。
727回答 すべてを表示
there is a network problem.Replaced the wifi nic card and it persist?
i bought a wifi nic card for the xbox one. replaced my old non working card but i still get the "there is a hardware problem" when trying to set my xbox up. i reset the xbox so i dont know if there is a way to bypass the start up screen.
I really want this to work.
before resetting the console i was able to use ethernet. now i cant use any of it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
I've had the same problem. In one I repaired the RF rol board was bad. Another one the customer had tried to repair and where the Wifi antenna plugged into the RF board was pulled loose.
Also make sure the WiFi card and the cable connection to the Mobo are pushed in all the way.
Hope you have already figured it out, please let me know if you did and what you did to repair it.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I replaced both the rf rol board and wifi board and no difference. While i had it opened the second time i had fully disassembled it and everything was plugged in properly but no go on any of it. Ended up just getting rid of it on ebay and picking up another xbox on ebay.
さんによる
コメントを追加
回答を追加する
Nicholas Everett さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 5
今までの合計 199
