メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1233回答 すべてを表示
iPhone not powering on
After reballing baceband ic my iphone can't turn on. I think that some component must de-aligned near the baseband and also it seems like there isn't C33 component on the board. Is it possible this to cause the problem and if yes where i can get it from?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
19 件のコメント
@toastedc0re post a couple of pictures of your board and your repiar with your question. Use this guide iFixitでの質問に画像を追加する方法 for that. It will allow us to see what you see. Also, how did you reball the IC?
さんによる
@oldturkey03 Added an image. Inform me if you want another one, and thanks for your help!
さんによる
Can you please inform why you reballed it in the first place?
さんによる
@toastedc0re thank you for the image. Any chance you can post one that has a bit less motion artifact? That would make it easier to identify the components
Rep: 31
さんによる
@packinit I tried to reball it with flux and a heatgun as the modem number was blank and imei didn't appear. I had tried before all the "solutions" that i found on the net.
さんによる
14件以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
I took some pictures of my 5c connector with an electrical microscope. It seems that there are missing to components. But I'm not sure if mine is complet because I also have some power problems other ones. Maybe these pictures help you.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thank you for your answer i'll check it out
さんによる
@hehe0903 from your pictures seems like I am also missing components near the battery connector. Seems like the missing components are more than I thought on the first place :/
さんによる
コメントを追加
回答を追加する
georgekarapi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 274
