メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Possible to extract data from water damaged phone? Location of LCI's?
Hi,
A friend of mine's iPhone 6 took a dip in water. She took it to a repair center. They extracted the data from it, but told her it's not repairable.
To start with; is it possible to extract data from a non-functioning water damaged phone? If the phone won't turn on (and is not repairable), how is it possible to extract the data from it?
Second, I opened it up to try to see where the liquid contact indicators are, in an attempt to see if they might have switched out the board for another non-working one. (My reasoning: if the LCIs on the board are not red, this would mean this isn't her board).
I was only able to find the one behind the SIM card tray, and it is red.
Anyone know where the others are?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It is NOT possible to dump data without powering on the phone and putting in the passcode, unless the user has icloud enabled and the data has been backed up automatically.
The other LCI is at the top end of the board.
このアンサーは役に立ちましたか?
スコア 5
6 件のコメント:
Thanks for the reply, Tom.
I just asked her, apparently they called her to ask for the passcode. So obviously the phone powered up. This might sound far-fetched, but is it at all possible to replace / swap some components with another functioning iPhone, to be able to power up the phone / gain access to the data?
Also, I've attached below a picture of the phone. The SIM card LCI is obvious. I cannot seem to locate the one at the top of the board. Could you pinpoint to where it should be?
Thanks again!
EDIT: I attached the image to my initial post
さんによる
My theory is that they simply cleaned the board and did some basic repairs so the phone can boot. They did not replace any core components like the CPU or the flash memory.
The second LCI is simply missing.
さんによる
But then how come, when she received the phone, it longer boots? Is it at all possible (as could it be done) to take out the flash memory and install it in a working iPhone 6, so they can extract data?
さんによる
No. Each flash memory must be paired with its CPU to load data. Otherwise it is not possible to decrypt any data.
さんによる
Sorry for being incessant here; just trying to understand the whole picture. Is it then possible to place the CPU and the flash memory in another functioning phone? Also, do you have any theories as to why they were able to boot up her phone but when she received the phone, it no longer boots up? Thanks a lot Tom, appreciated!
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Rawan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 231
