メインコンテンツにスキップ
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60回答 すべてを表示
Mother Board ASUS X550L
I have a Asus X550L which is not functioning anymore due to short circuit as what the technician said, the problem was its on board power chip which they said they have to replace the entire mother board which is cost a lot.
so does anyone can share a diagram of this or anyone knows the exact details on that
power chip because now a days Im sure we can search or order it online..
please help thanks..
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Sheldon,
This link shows the input unit of a laptop motherboard (DC jacket, capacitor, etc.). It might help you to localize where the power IC is on your motherboard.
There might be a diagram available for your laptop here. However, you also need to have the program to view the file.
I hope this helps.
Steffen
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
thanks ill go look for a program to open the file..
さんによる
コメントを追加
回答を追加する
Sheldon Semblante さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 1,708
