メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1158回答 すべてを表示
Ear peice and proximity sensor not working
I replaced the headphone jack on my iPhone because I was not getting a good connection to various headphones. In putting it back together I must have not connected connector 3 correctly. I have tried a number of times to reconnect it. Does anyone have a photo of what it should look like or any suggestions as to what I may be doing wrong? If not what is my next step?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
5件の回答
ベストアンサー
Could be your connector? It is hard to notice, but sometimes they break and lift off the board slightly.
http://hectordtruong.blogspot.com/
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Here's a pic (the model in the pic is a 3GS, but the connector is the same in this instance):
It has a gold tip that should be completely in the connector. Make sure the locking bar is down once the gold tip is in there.
Have you tried restoring it, or can you not get that far?
If that doesn't fix the problem, it seems that the front panel/digitizer is broken.
If THAT doesn't fix the problem, all signs point to logic board.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
さんによる
コメントを追加
I Must have knicked the #3 cable while putting it back together. I too purchased a new cable, and although it is not the easiest thing to replace I did do it and now everything works wonderfully.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
+great! now you can accept your own answer
さんによる
+ (You forgot your tick pollytintop)
さんによる
oops, thought it went on.
さんによる
コメントを追加
Might not be the logic board. That ribbon cable is fickle. I ahd this problem and just bought the cable (proximity sensor cable) off of amazon and replaced it. There's a youtube video on how to do it (since it's not immediately obvious), and it's an easy repair.
Also, remember to always shut off your phone before you open it. Seems that the proximity sensor or the cable may be especially sensitive to that.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
さんによる
コメントを追加
dam im such an idiot i was trying to lift the white part of the connector and not the black thing and i then chipped abit of the white part but it has not tottally fallen off and the ribbon still fits in there thankfully but i guess its damaged and now i know how to fix it properly
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Scott さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 5
今までの合計 7,896
