I see you have ram,
2 gig for this mac, can I upgrade directly to a pair of 2 gig chips? Take it from 1 gig to 4 gig ram? Am I able to put a 2 gig chip in each slot?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The 20" is A1207, the 24" A1200 both use the same RAM
MAX RAM is 3GB of PC2-5300 DDR2 SODIMM
Here's how to install it: http://support.apple.com/kb/HT1432?viewl...
このアンサーは役に立ちましたか?
+ here too.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 781
6 件のコメント
can you specify the model number?
palokiller さんによる
You can find this out by using our ID-Your-Mac tool.
Taylor Arnicar さんによる
iMac "Core 2 Duo" 2.16 24-Inch Specs
Identifiers: Late 2006 - 24" - MA456LL - iMac6,1 - A1200 - 2111
I am asking because on a PC I have heard you cant mix he sims. You cant have a 1 gb and a 2 gb, for example. you have to have 2 sims the same. Is it a problem with my mac?
themeofsecrets さんによる
It's not a PC.
mayer さんによる
Yeah I kinda goofed that one. Communication is beautiful only when it works, right? What I should have said is that I have a PC also - I bought the MAC and am transitioning from the PC to the Mac. I know on the PC you have to have the same sims. If you have 4 slots you have to have 4 1 gb sims, or whatever. You cant have a single 2 gb sims and 3 one gb sims. Is my Mac the same way? I have read I can only use 3 gb max, and I have 2 slots. Can I use a 1 gb and a 2 gb sim instead of 2, 2 gb sims and just not be able to access all of it?
1以上のコメントを表示
