メインコンテンツにスキップ
Device repair and information for the Plantronics Backbeat Fit 2100, wireless sport headphones released in August 2016.
17回答 すべてを表示
How do I fix my backbeat fit?
I bought a Backbeat FIT and after about 3 months it stopped working, it won't turn on or anything! It still charges(the light turns on when plugged in) but won't actually turn on! I'm frustrated because I spent $130 on headphones, 3 months later Platronics in telling me I need to pay $95 to replace it!!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 41
28 件のコメント
My Red Backbeat Fit came DOA. Buttons not stuck or anything, just won't power on or take a charge. Red LEDs come on when plugged into a charger but even left overnight doesn't go to blue. Power button completely unresponsive, no LEDs come on when unit is not plugged in.
さんによる
Mine turn on and off and says that it is charged but does not pair anymore with any device
さんによる
Experiencing the same issue on a Backbeat Go 2. Won't turn on, charging LED turns on but keeps charging forever after 3 years. Wouldn't recommend Plantronics products.
さんによる
Same thing as one of the comments above - DOA. Will not even power on. Will indicate red for charging while plugged in but will never turn blue. No stuck buttons. Just broken.
さんによる
Was there a solution at all? This has just happened to me too. And I’ve only used it twice. Can’t find the receipt. So frustrating. What a rubbish product!!!!
さんによる
23件以上のコメントを表示
コメントを追加
33件の回答
最も参考になった回答
I had this same issue and after some troubleshooting I realized that the left-side earphone control (the one that allows you to play/pause) was sticky. That is, it was 'stuck' in pressed mode, causing all other functions to fail (like the OP stated, charging still worked).
So, there's a flakey solenoid (or something). My temp fix is to lightly tap the left earbud against something hard in the hopes that this action will dislodge it. To avoid having the button stick again, I've been controlling the audio via the iPhone controls (which sort of defeats the purpose of not having to retrieve the phone from one's pocket, but hey - one thing at a time).
このアンサーは役に立ちましたか?
スコア 23
19 件のコメント:
I've got exactly the same issue. Play pause button is stuck, was charging but now not. Earphones dead, and similarly just months old.
さんによる
Returned to store, replaced it on the spot.
さんによる
Good work. Hadn't used mine in months and had it sitting in my car for that entire time. Button got stuck and I knocked the pause button loose by knocking on it with my knuckles. Good as new.
さんによる
Cameron you are a life saver. Had the same issue, so kept punching the left knob, now it turns on finally. Mine is out of warranty phew!
さんによる
Wow, just when I thought it was beyond fixing your were a life saver!
さんによる
14件以上のコメントを表示
コメントを追加
I thought I had the same issue. I contacted tech support and there is a tiny little clear button on the edge of the power button. Once I depressed that tiny button, it powered on. The instructions do not do a very good job of pointing this out. Hope this helps some of you guys.
このアンサーは役に立ちましたか?
スコア 8
14 件のコメント:
Thanks so much for this, was on the verge of returning mine to the shop but this did the job!
さんによる
Hi Edward,
Where is this little clear button.
I can't find it.
Thank you in advance,
Vladimir
さんによる
Thank you. Tech support couldn't help me resolve this. That fixed it.
さんによる
I wasn't able to find the button either but I carefully lifted the outer ring a little and snapped it back in. Right after this I was able to turn it on again and it flashed orange/blue.
さんによる
Thank you rikobeck!! I ended up taking off the entire outside ring. Be really careful if you do this because the power button is nothing more than a small clearish piece of plastic. It is easy to lose.
You have to carefully place it back on top of the dimpled spot. The other trick is aligning the ring before snapping in place. If possible remember how it came off. All this being said, I fixed it!!
さんによる
9件以上のコメントを表示
コメントを追加
I just fixed my earphone that did't charging. The problem was in contact with the USB connector and the PCB
このアンサーは役に立ちましたか?
スコア 5
9 件のコメント:
How did you open it, can you tell me where exactly we need to detach it?
さんによる
Carefully lift out the plastic outer ring on answer button. Don't lost small plastic power button! Then bend out the part where the loudspeaker is. If you're lucky, you don't break plastic clips which keep the parts in one another. Maybe warming up helps, there is glue inside.
The press the device out of its frame, don't damage cords.
After that yout have to open it like a mussel. In my case, there was corrosion on the PCB's USB connector contact surface.
When I assembled it back, I used silicone glue
I think that in my case the fault was that I did recharge too soon after heavy use and washing.
It is better to let it dry properly (several hours)
さんによる
Than you so much for explaining.
I am very lucky this time.. though warranty was 1 month before, service center agreed to give a new version without even asking single question.
さんによる
Zava , how can i press the device out of its frame ?
さんによる
Is there any way to buy power button bcs i lost mine
さんによる
4件以上のコメントを表示
コメントを追加
I bought mine about 6 months ago; expensive! Used it 3-4x and it stopped working. Worst product ever! I basically spent $130 to be disappointed! I'm furious! I charged it for 2 nights straight and the light never changed from red to blue.
このアンサーは役に立ちましたか?
スコア 4
9 件のコメント:
I am having the same issue. I won't hit them or whatnot but this is rediculious and way too costly. I wish I had seen this first. Not a happy camper!!!
さんによる
same same such a pain
さんによる
Same problem here.. so disappointed!
I will bring it to a service center and see if they do something about it.
さんによる
Exactly the same problem.
Did someone solve or know how?
さんによる
Exact same problem here. Very disappointed!
さんによる
4件以上のコメントを表示
コメントを追加
I bought this Backbeat FIT too and after few months it stopped working, it won't turn on. the light is still turns on when plugged in, but won't actually charge. I don't know what to do.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
there's a 2 year warranty. go to their website and enter your serial number
さんによる
コメントを追加
Class action anyone? Plantronics should replace with working and non-defective products. You can't fix, they won't replace. I am not a sue happy person, but paying $130 and nothing working makes me RED!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
So glad I found this site. I’ve had my BackBeat FIT earbuds for 3 years now, and recently started getting the “sticky left button” issue. Until recently it was just the annoyance of the earbuds skipping my music tracks and hearing the voice repeatedly say “next track…next track.” But then last week they failed to power on, despite the battery being 100% full (blue LED after charging for a couple hours).
I tried banging the left earbud on a desk a few times, then repeatedly pushed that left button until it got unstuck. Suddenly the power-on button started working and the computer voice said “battery full, headset connected.”
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
thats hilarious.i fixed mine a similar way,but it wouldnt take a charge.i dissected them with no good results.they are still great earbuds.i put them through !&&* and they took it for a lot longer than i expected
さんによる
exactamente. Recomiendo a todos que lo hagan. Golpeen con confianza !
さんによる
コメントを追加
It is extremely hard to fix anything with this speakers, Plantronics service says it is not repairable, but... I can trot out that I have replaced one speaker from broken one my (green) with successful
below picture how it looks like - very tiny :)
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
May I know the procedure for opening it?
さんによる
Hi, i wish you can explain how disassemble the earbud I order to repair it. A video is much appreciated. Thanks
さんによる
コメントを追加
I bought a pair of these headphones as the ones i originally had-which were great by the way-broke. When I received the headphones, they would seemingly charge, but never complete the charge as the indicator light remained red. I returned these and ordered a new pair, but they did the same exact thing.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Exactly the same thing happening to me and my wife!? So frustrating!! Has anyone contacted plantronics direct?! So filthy!!!
さんによる
コメントを追加
People, we really should start a class action for this, a petition of some sort.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I just got these yesterday let all three charge all night only 1 of them turned on do you know what's wrong?or how to fix them?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I lost 2 of these to the same issue - worn’t turn on. The first one was refurbished, so I wasn’t so upset, the other one was brand new, lasted less then a year. I love the fit of these earphones but the durability is so poor!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Having a similar issue as a lot of people. My headphones won’t charge and won’t power on. When I plug them into a charger the light doesn’t even turn on. This is unexceptable for $130 headphones. I’ve barely used them and now I have a $130 paper weight as a result of nothing I’ve done. Has anyone tried to take these to a local repair shop to have PCB looked at? This seems like a prime example of an issue that deserves a class action lawsuit.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Well well well, a year later almost to the day and there is actually a class action lawsuit against Plantronics LOL
https://www.headphonesettlement.com/
Go get your settlement checks everyone, this type of stuff is inexcusable.
さんによる
コメントを追加
I got a pair for my birthday from my colleagues. Thanks to it I became a gym freak and lost some weight. My wife, seeing my weight loss, decided to get a pair for herself. Cost a lot of money for us in Malaysia. After using mine for 4 months, it no longer charges. My wife’s, after about 6 months, no longer turned on.
This bad experience made me never to trust bluetooth head/earphones with irreplaceable batteries.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
CLASS ACTION LAWSUIT IS A GO PEOPLE, JUST RECEIVED THE EMAIL FROM THE LAW FIRM
Everyone go here and submit your information, you’ll receive at least $25 or up to $50 if you have documentation. Plantronics deserves to lose every single cent they can for an issue this wide spread.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Same problem here. I bought mine 10 months ago and they suddenly stopped working, they charge, I get the red light and blue light when charging, but that's it, nothing else seems to work. Plantronics won't help me either.
I finally had to throw them away. What a waste… I’ll better stick to well known brands with good customer service. Now I am using my Jabras Active 65T for my quarantined home workouts. These are awesome.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I bought my backbeat 305 around 8 months back and now one side doesn't work. How do I get it to work as it used to before?
さんによる
コメントを追加
Exactly what happened to me. I played around with the play and other button on the opposite side to the power and it came right. Looks like a sticky button remaining on so the power button won't work. See how long it lasts I guess. Push the buttons many times to try and free it up.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same problem - left-side earphone control ( play/pause) was 'stuck' in pressed mode. Try to push many times, nothing to happens. What can I do else?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Thaaats not encouraging...at all! Almost exactly three months, same spot; waiting to hear from them tomorrow
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
You have to return the product - they're clearly flawed. I've got a replacement, will see how long that lasts - local store asked no questions. The new one has a play button that feels dodgy too.
さんによる
I have this problem that just the left side stops working, the play/pause and volume controls works fine but the earpiece is dead. Any advice? (6 months use)
さんによる
コメントを追加
I bought mines at Costco, worked perfectly fine for only 1 year, cant return them because its only 90 day policy. Left side is very sensitive and have issues powering on/off. Love the product but will never buy again if I dont get one replaced by Plantonics. Still have original packaging
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Apparently there's a problem with these earphones.
Some sort of product failure.
I suggest do not try to open it up and fix it, it is likely be more complicated to put back. If u can bring it back to the store for replacement. I had mine replaced only to receive new malfunctioning ones, with the same problems. Now I am waiting for them to bring in new earphones from a different branch. All in all, it's been 3 months of on and off tango with the vendor in order to get new ear phones that are in working order.
My advice to y'all, do not buy them, and if u did, try not to fix them yourself.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Definitely a manufacturing problem, those earphones are flawed from factory. Just check this page to get an idea of how many are experiencing charging issues. Definitely not worth the money spent. https://www.facebook.com/Plantronics/pos...
さんによる
コメントを追加
Just got a brand new back beat fit brand new I charge it but the color never changes to blue from red I left it chargeing over night and it will still be red can anyone help me out.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Somethings is wrong, after about 1 hour led should change to blue, try other charger with other cable, if doesn't help then probably only service left :/
さんによる
コメントを追加
Is there an image of the battery?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I don't have image of battery, it is on another side and I didn't open it.
さんによる
Oh My!!! Just bought (VERY PRICEY) Plantronics BackBeat FIT PLT Waterproof Sport Wireless Bluetooth Headphones. I’m cancelling my purchase & asking for a refund. Any suggestions as to what I should get now??? At a loss, but I appreciate the input from you all. Who’d want to go thru try this, do that, find this send that? Not i nor will I. This company can’t continue to sell these and replace them without going under. I won’t do this. Good luck everyone! Don’t forget to let me know what other headphones you recommend that is reliable and dependable if you can.
さんによる
コメントを追加
Hello everyboy (I'm french you'll excuse my ortograph..)
I just had the same problem as everybody here. My headphones didn't want to turn "ON" (even when battery fuly charged overnight) and when it was charging mode, the color appears blue and red in the same time. This problem appened to me just after tryin to uptade de processus with the app' phone i just downloaded from official plantronics backbeat FIT.
So I tri every thing poeple are telling here with no succes. And then, i had the idea to delete the app from my phone, re-download it and try to connect my headphone to my phone. To do that I just puch on the power button until it the red and blue light appears (keeping the power button press in te same time) and suddently my phone app asked my if i want to connect my headphone ! My headphone work again and the app was normaly uptade !
Maybe you kan try it ? It worked with me..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had same issue with headphones. I manage to open it, checked all connections and finally found the solution for this product. It took approximate 2 minutes from my desk to trash bin. I placed on order apple airpods.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same problem. After 25 months of usage left side play/pause button got stuck in pressed down mode. So, it is possible to charge, but I can't turn them on. I opened them up and it turns out, that water has accumulated and the whole thing is covered in rust. Not sure I can revive this thing.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hey, I bought mines on 2015 and they work perfectly all this time. These day I can see the left buttons are stuck, the one with pause and play. I have open the right side to clean but for the left side I don´t know is possible to open without breaking something. How did you open yours?
さんによる
コメントを追加
Was anyone successful replacing the battery on their own? What type of battery does it have?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My case for my ear buds won’t charge
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
My case will not charge my ear buds
さんによる
Charging my case won’t hold charge
さんによる
コメントを追加
reset the headset then update them through the app for back beats go worked for me
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
To anyone with a Plantronics Backbeat headset that wont tun on I found a fix. While holding down the power button, plug in the charge cable and it will reset the device and it should start working again.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Been stored in a drawer for ages (2 years or more) charged OK but no controls. Gave it a bit of a clunk o the worktop a few times and a light dusting of WD40 quickly wiped off. Hey presto buttons free now, I guess I would be bit stiff if I had been in that drawer for a few years. All sorted now. So happy I came across this site.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hey all, For those who haven't been able to fix the issue by using the hot tip going - around which is giving the left bud a light tap to unstick the button - then the second step is obviously asking for them to replace it. "But I don't have the receipt", then if you haven't already, download the 'Backbeat' app. make sure your buds are paired, then in the settings (at the top right of your phone screen) scroll down and see the headset support button. Your app will assemble an email for you to send to Plantronics so they can help you out with the rest.... most people get refunds without receipts.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
the power button is shown.
このアンサーは役に立ちましたか?
スコア -1
3 件のコメント:
whats the procedure in attaching can you provide one please
さんによる
Hi, i also opened it up, but i cant reattach it. How did u do it
さんによる
Do you know what type of battery they have?
さんによる
コメントを追加
回答を追加する
Ezra Gloetzner さん、ありがとうございました!
統計データ:
過去 24時間: 40
過去 7 日: 183
過去 30 日: 710
今までの合計 197,353
