メインコンテンツにスキップ
2.0GHz, 2.3GHzもしくは2.6GHzクアッドコアIntel Core i7プロセッサ (Turbo Boost 最大3.8GHz) 6MB共有L3 キャッシュ付き。
580回答 すべてを表示
Backlight stopped working, is self-repair an option?
Small spill on keyboard and the back light stopped working. I tested the lcd with a flashlight and that still works.
I've seen a lot of questions on this topic, but none for this specific model. Any help with what to check would be very much appreciated!
  • MacBook Pro 15" Retina, Late 2013
  • i7 2.3Ghz/ 16 GB/ 512 GB
  • SN #: C02MT1RCFD57
  • MB SN #: C02421501BCFP5219
Edit: The lcd works, but the lcd backlight does not. The computer works when used with an external display.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント:
So... Does the keyboard still work? And it's just the backlighting that's broken or what?
さんによる
Does it work with n external monitor?
さんによる
The lcd backlight is the only thing broken. Everything else, including using an external display, works fine.
さんによる
コメントを追加
1 件の回答
I've just started messing around with the retina displays but it seems like the screen has so much adhesive that it seems impossible to replace without breaking it. Maybe if you use a heat gun, that will soften the adhesive enough that you could pull it up.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jesse Walton さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 103
