メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Do I need to purchase a heat shield plate or LCD digitizer?
My phone suddenly went blacked out and it couldn't be turned on after I delayed on replacing the bloated battery. The situation was so bad that my LCD screen was seen being pushed out slightly. Now that I have replaced the battery, the whole phone couldn't be turned on. To make things worse I accidentally scratched the heat shield on the shield plate as it had bent it slightly.
So my question is what should I do now? Should I purchase a LCD digitizer and give it a try? Does iFixit offer refunds if purchased items doesn't work out for their customers?
Thanks in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
The heat shield should not affect the phones functionality. Its there to protect the LCD from excess heat, but your phone should still power on without it.
The issue shouldn't be with the LCD if it was working prior to the install of the new battery.
Do you have more than one new battery?
Have you plugged the phone into the mains without the battery attached? If so what happened?
If the phone comes up with the fruit logo with the battery detached, then your issue was with the battery and you will need to get it replaced. Not all new batteries will function and if you do not have a battery booster you will need to get a new battery.
I hope this helps
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Actually the LCD wasn't working before the installation. It could have broke something in between.
I went to check it again and I think one of the three cables is dangling loosely and could be while installing I had broke that cable which links to the LCD.
さんによる
コメントを追加
回答を追加する
Guang Ong さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 2,452
