The tablet will turn on, but the display does not work
I can touch the screen and hear noises like I am selecting something, so it responds to touch, but the screen is black.
Hi Jenny
Can you try to restore the tablet to factory settings through combination of physical buttons?
Simultaneously press and hold the Volume Up and Power button until "Ellipsis" appears then release. ...
Select wipe data/factory reset. ...
Select Yes-delete all user data. ...
Select reboot system now.
If you can get it into hard reset mode the screen may appear.
If not you would need to go to repair shop and get new LCD to see if this can solve the problem.
Hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 1,197
I also am having the same issue. Surely someone out there knows of a fix for it! Lets hope we hear back
mmiller569 さんによる
