Two Camera Not Working
hi
After Change LCD Two Camera and flash Not Working only see black screen
i need solution
Thank alot
Does your earspeaker work? If not, it's possible that you damaged the front camera flex, which can cause a failure of both cameras and flash.
Otherwise, try turning it off and on again (I know, basic but sometimes it works!)
このアンサーは役に立ちましたか?
i change my front camera and flex if my front camera not working , All camera stops working?
earspeaker and sensors is working... Camera Regulator is U3200?!
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 175
