メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Phone won't turn on and Error 4014
Hi there,
This second hand iPhone 6 I purchased is not turning on at all, and when plugged into iTunes it doesn't vibrate or show any indication of life, but then shows an Error 4014 when trying to restore. I believe the phone is in recovery mode because it will not turn on or show any sign of working.
I thought it may have something to do with the inside of the phone, so I opened it up and saw that the battery was slight swollen and smelt of chemicals (nail-polish/fruity type smell).
My question is are these two issues related, and if I get the battery repaired, should I expect to be able to repair the error 4014?
Thanks in advance
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
It's definitely worth a try. Battery shouldn't cost too much.
さんによる
コメントを追加
2件の回答
最も参考になった回答
I would try replacing the battery.. but i would first unplug the battery and plug it into the wall outlet and see if there is any sighs of life.. problem could be more then a battery
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Good idea. Will try that soon.
Thanks
さんによる
コメントを追加
its fixit and texted . SEE here photo after solved. this Error Solution Not Easy Remove and fix . Error 40 ,4013 , 4014 , 9 all same solution
1) fast remove nand carefully because you need sn /bt/wifi address from nand.
2) repair nand with any repair tool
3) back nand in motherbord and restore full
4) done .
this work dont this to Easy . thanks
Done Error 40 ,4013 , 4014 ,9
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Zac Webb さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 904
