メインコンテンツにスキップ
Released in November 2013, this model of the HP 2000 series is the perfect device for those on a budget, but don't want to sacrifice performance.
35回答 すべてを表示
My laptop is stuck at the hp logo starting screen.
everytime i turn on my laptop it gets stuck at the loading screen and then turns black for a second then repeats. i tried removing the battery and holding the power button for 30 seconds and it still doesn't work. Any suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
- Have you tried checking your memory modules to see if they are seated correctly?
- If you have more then one memory module, you can test your modules by trying to start computer with each individual module.
- Is the hard drive full? 15% or less available space, the system will freeze.
- A bad hard drive can also cause the system to freeze. I would connect it to another computer and run a program called Crystal Disk Info to check the health of the drive. If it's in the yellow or red, I would pull off any important data before the drive completely dies.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
itzcristiano gaming さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 517
