メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony Xperia Z3 発売日:2014年9月(グローバルモデル) 日本国内取り扱いキャリア docomo(SO-01G)・・・2014年10月23日発売 au(SOL26)・・・2014年10月23日発売 Softbank(401SO)・・・2014年11月21日発売
Adhesive issues , so very different
Hello
So i repair many Sony phones that are mainly based on glue, and even tho i have the correct adhesive strip for the job, it seems the 30% of the phones repaired, the adhesive will not stick the LCD/digitizer properly to the front of the device.
i apply heat after placing the lcd/digitizer on and i use small "clamps" to keep it all in place.
Tips and tricks boys?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
What type of adhesive are you using? How do you apply the adhesive? What sort of material are you gluing together? Glass on Metal; Metal on Plastic; or Glass on Plastic?
For many different material I prefer two part epoxy which if you have clamps or something you can use to hold the two different materials together you can wait for the two part epoxy to dry. But if I do not have the time to hold the two materials together or the materials are hard to get to stick together I use Superglue specifically one with a brush applicator which is easier to make sure the glue is applied evenly.
If it is for a material that has high heat and has a constant pressure already holding the materials together like a Gasket joint I use RTV which will create a water proof seal and resist high heat. RTV is also good for keeping electronic wiring together "close" but separate for to maintain a plastic covering. You can also use a glue gun for this also but RTV has the High Heat protection that some circuits need.
I do not know if this answers any of your questions, but I hope it helps someone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Melvin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 143
