Fast charging not working Galaxy Note 4
I have a Galaxy Note 4 through sprint that will charge extremely slow. If the screen is on, it will still cause the battery to drain. I have connected 3 different Samsung Fast charger adapters with multiple cables. They all work on my Galaxy S6 but not on my Galaxy Note 4. I have replaced the battery with OEM and Non OEM batteries, replaced the charge port with an OEM charge port, and even replaced the screen with an OEM screen. I am still not able to get the Fast charger to work. I also did verify that the Fast Charger setting is turned on. Does anyone have any idea's what I can do?
8 件のコメント
How slow is extremely slow and how long does it take to charge. By the way the phone will charge 2 amp ~ or around there max. Average 2-3 hours from 0 to 100%.
Ben さんによる
If i have it turned off it takes around 5 hours to charge, if I have any apps opened and running it drains faster than it can charge.
Elliot さんによる
Turn off power saving mode if you have it enabled and keep fast charging on and see if that helps.
Ben さんによる
i tried that, I also factory reset the phone and it still will not fast charge. I am pretty sure it is going to be something with the board, so I am sending it into samsung., But I appreicate your help.
Elliot さんによる
ever since the note 7 drama. Samsung has started fingering its charging code. I have the same problem which started the day after I updated to the latest firmware. Which is fast charge wont work. Nothing works in fact. The only way I could get it to charge is to use a very old dumb charger with a max output off 500 mili amps. Or plug it into the PC where data and slow charging happens. If its the port how is it able to charge and transfer data from the PC. USB doctor shows that if I use a smart charger it just shuts down the charger i.e. output goes zero. Charger shuts down.
THANK YOU SAMSUNG for messing with a perfectly working phone.
Plan to take it to a service center but their response is the same. Change port. Buy new bat and charger been there done that no help. The best part we cant even roll back the s/w without rooting and triping knox. Maybe I will try that next.
Rohinton Chinoy さんによる
3件以上のコメントを表示
