メインコンテンツにスキップ
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459回答 すべてを表示
Charging paused. Battery temperature too low.
I originally had a power button problem, but fixed it by removing the old power button and soldering in a new one. Now the power button works! But the phone no longer charges. Every time I plug it in, I get the error message "Charging paused. Battery temperature too low."
I don't think it's the charging port because a) it worked fine before the power button replacement and b) I bypassed the charging port by connecting USB wires to the little open ports in the back of the phone like this guy demonstrates (https://www.youtube.com/watch?v=mwTrlMom...) and trying to charge the phone that way - same problem.
I don't think it's the battery because I used two other batteries and encountered the same problem.
In addition the phone can't access the camera, so I think that part of the board is fried somewhere, possibly one of the itty bitty resistors, or maybe a short somewhere. Or maybe the thermistor, but I don't know where the thermistor is, what it looks like, or how to check if any of the resistors are blown.
I'm getting a new motherboard, which is the logical solution, but it would have been fun and interesting to be able to fix this.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
Hello Harry,
Sorry for your situation, new board and all. For me, I would imagine it's one of 3 Issues.
  1. 1: Battery - you solved that one
  2. 2: Charging port - A lot less likely as it wouldn't really give you that message
  3. 3: Your Charging IC - Real possibility, easy to short or damage while repairing.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks for the response Eddy! It's nice to know you've been seen, even when there's no solution.
I agree with you: probably not the battery or the charging port. Very interesting that it might be the charging IC. I'm going to try to check it out, but I'm not sure how I would repair it if that's the case... but I'll see what I can find.
さんによる
コメントを追加
回答を追加する
Harry Cole さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 8,972
