Will not charge or power on
You troubleshoot your tablet like this. No power or charge. Start with cable and outlet to make sure that it's not a bad charging cable. Next you go to charging port and on/off power button. Check if you see damage to the charing port and next you test out on/off power button which may require you to open the case of the tablet. If all those passed you're troubleshooting test, then you start with the logic board. But at this point it start to get technical and requires special equipment to further test your tablet.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 111
john266a what model tablet? what have you checked? The more information you provide the better your chances to get a valid answer
oldturkey03 さんによる
