メインコンテンツにスキップ
New Nitendo 3DS XLは2014年10月11日に発売されたNintendo 3DS LLの後継モデルとして、日本国内で発売されました。北米では、2015年2月に発売されました。
373回答 すべてを表示
Are N3DSxl ribbon cables ordered, and facing in the right way?
Hi guys,
In my picture you can see 2 ribbon connectors on the motherboard in the back... One has a black lever and one has a white lever...
Which way should the gold pins be facing?
I purchased this unit partially disassembled and cannot find clear images of this part.
http://imgur.com/uVPG8Ax
Thanks for your time!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
I don't have a XL in front of me but I do remember the order and the way they should be facing. This order will be based off your picture and the way you have it positioned there.
The closest ribbon will be the top LCD ribbon, the gold pins should be facing you as they will be facing "away" from the PCB when reinstalled.
The middle ribbon will be the camera ribbon, the gold pins should also be facing you. When installed into the PCB, it will be facing "toward" the board.
The furthest ribbon is the speaker/3d slider ribbon. This one can be a bit confusing since it's bent and installed into the PCB. These pins should also be facing you before installation. When you go to install the ribbon, the ribbon is flipped over, giving it a 45° angle. When it's installed into the PCB, the pins will be facing away from the board.
It appears that all of the gold flat pins will be facing you when passed through the hinge and I also guess it doesn't matter if the speaker and camera ribbons are flipped with each other, it just may make installation a bit trickier. Make sure that your top LCD ribbon is the closest to you. I generally find it easier to install the ribbons in this order: Camera, Speakers, then top LCD.
Note, this is based off the N3DS XL, not the LL model (which has the right analog stick nub). I hope this helps answer your question
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ultimaweaponx さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 92
今までの合計 2,234
