メインコンテンツにスキップ
Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
110回答 すべてを表示
Problems with battery after screen replacement
Hi! I followed the teardown and changed my whole screen frame and now the phone is not charging. It boots but stays a 0% also once i force it to boot and it shows lock screen it automatically shuts off.
Did i damage the battery or not connect the charging decide correctly?
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
The teardowns are not meant to be followed as repair guides, so you may have disconnected something in the process.
I would have a look at our display assembly replacement guide and see where you might have missed something.
OnePlus One Display Assembly Replacement
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
is there a indicator shows when you charging the battery? if there is no sign , would it be the problem that the charging port flex cable is not connecting well with the motherboard? if it shows charging but actually not charging maybe it's the battery not connecting to the motherboard well. just a guess.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
manulaudic さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 251
