メインコンテンツにスキップ
モデル番号 A1213/ 8, 16, 32 GB容量
216回答 すべてを表示
締切られた回答
Phillips screwdriving not working in screw holes
Has anyone else had this problem? This is my second 1st gen ipod im fixing and I have run into the same problem as last time, the screws holding the logic board in place (ones near the anntena) arn't working with the phillips screwdriver in the opening tools set.
Any solutions to this and is there a way to avoid it in the furture?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You may be using to large a bit and it's not going all the way down into the screw.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Well I am using the screwdriver that comes with the opening tools, so you know the screw size for ipod touch's thats are 1st gen?
さんによる
I have found a solution that works very well for this problem, hit the top of the screwdriving while ontop of the screw about 5 times with a heavy hammer, makes the screwhead bigger and works perfectly with the screwdriver
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 2,153
