メインコンテンツにスキップ
The ZenFone 5 is a 6.2" smartphone made by Asus, released in May 2018. The phone has two rear-facing cameras and comes in Meteor Silver and Midnight Blue.
18回答 すべてを表示
After replace display, Asus zenfone 5 stays on only with power cable
Hello everyone! Sorry for my english :)
I have a asus zenfone 5 who fell and as a result has cracked the glass. I bought a kit for the replacement of the display and yesterday I replaced it.
The display works perfectly but there is a problem: the phone turns on only when I plug in the power cable and goes out as soon as I remove the cable. Once you turned on the phone the power and volume buttons works and the battery is detected and appears to be in charge, but without the power cable the phone is not working. I also tried to disconnect the connector that connects the battery to the phone and the phone still comes on connecting the power cable, however, does not detect the battery.
What can it be? Should I try to replace the battery? Or is it more likely that damage has a connector (does not seem to have broken anything).
It 's really weird because when the phone is connected it works and it is in charge.
Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
check the battery flex cable or measure the battery voltage with a multimeter
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Miriam baraldi さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 5
今までの合計 429
