メインコンテンツにスキップ
6th generation Android smartphone designed by Google and manufactured by Huawei. Released October 2015.
63回答 すべてを表示
Major liquid damage, how to extract memory?
I accidentally took my phone into the ocean while on vacation, and now the device won't power on. I'm pretty much resigned to having to buy a new device, but there were some photos and videos I took while out of coverage area and I really want to get them back.
Is there any way to read the memory onto a working computer for recovery? I didn't get the accidental warranty so I don't think this would be covered, but I really want those photos :(
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Jared Harder sorry to say but you can not access anything on the phone unless it powers up. No recovery software will work for that (You'll get lots of answers with those suggestions). The only way would be to fix your phone to the point where it may power up long enough to remove your images. Use this teardown to give you an idea on how to open your phone. The use this as a how to guide fior the cleaning. It was written for an iPhone but all the points are still pertinent to your phone as well. Remove all the EMI shields on your board to clean it properly. After that replace the battery. Hopefully you get it to turn on, download your images and then see what you get. Otherwise your files will be lost for sure.
iPhoneの画像
ガイド
iPhoneの水濡れ・水没ダメージからの復旧方法
難易度:
難しい
1 - 2 hours
Nexus 6Pの画像
ガイド
Nexus 6P Teardown
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Jared Harder さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 224
