iTunes Restore failure 50
Hi, i tried to restore the iPhone 5c via iTunes in the DFU Mode because it is unable to find carrier net.
While restoring it iTunes permanently displays failure 50
Hi christophgabl
try to uninstall all iTunes and restart your pc
then install new one and see if is okay otherwise
iTunes error 50 is a commont '''can't connect to its database server which prevent you from accessing your library and syncing data, also occurs when you try to download from iTunes Store. ... Corrupted iTunes'''registry on your Window
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 41
