メインコンテンツにスキップ
2012年6月発売。Core i7プロセッサ 、Turbo Boost / 最大1 GB DDR5 Video RAM
596回答 すべてを表示
2012 MBP Parts Swap
So I have two partially broken 15inch Macbook Pro's, an A1286 2011 and an A1286 2012, The 2011 has an Anti-Glare Screen but a bad motherboard, and the 2012 good logic board with the 1gb of vram, but has a damaged screen and trackpad. I just wanted to know if it was possible to take the screen and trackpad from the 2011 and put them into the 2012?
I was told that screen connectors might be different and I may have to mod the cable?
Has anyone tried this, is it doable? Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hey there! I have good news! The trackpad and display are both totally interchangeable. The cables on the display are even the same. The only difference between the two displays is that the 2012 has a better webcam.
Best of luck in your repair!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
The display connector on a 2012 is slightly different, you may have to bend the one on your logic board. 100% works though!
さんによる
コメントを追加
回答を追加する
Dontae さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 194
