メインコンテンツにスキップ
冷凍庫の修理情報
192回答 すべてを表示
Why is my upright freezer leaking a "lot" of water from underneath?
My upright freezer is leaking a "lot" of water from the bottom! I don't think it is quite as cold as it usually is, but the food is still frozen. I hear a noise, but not sure if it is just a fan, or motor, or compressor. Don't think it sounds as it normally does. The water covered my entire garage floor...I can feel cool air coming out the vents on the inside, but the foggy stuff isn't circulating.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Cause 1
Clogged or Freezing Defrost Drain
During the freezer’s defrost cycle, the defrost water exits through the defrost drain. Sometimes, the defrost water can freeze over the drain. If the defrost drain is clogged with ice, the defrost water will overflow the drain and leak from the bottom of the freezer. To thaw the ice inside the defrost drain, use a turkey baster and hot water to flush the drain. If your defrost drain freezes regularly, consider installing a drain heater to melt the ice.
Where do you live an how cold is it in your garage?
このアンサーは役に立ちましたか?
スコア 7
1件のコメント:
It is not in garage but in the basement, which is set at 68F. Ontario, Canada
さんによる
コメントを追加
my door was lift open by mistake none it will not freeze all the can you please help.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
my freezer leaks from underneath ive told my new landlord but he just says thats what happens its about 6 yrs old it never did that before
さんによる
my freezer is leaking from bottom my new landlord says its ok thats what happens but it has never done that before its 6 years old
さんによる
コメントを追加
回答を追加する
gracie1rda さん、ありがとうございました!
統計データ:
過去 24時間: 21
過去 7 日: 85
過去 30 日: 469
今までの合計 51,574
