Why is my tablet keep turning on and off
It turns on and then off and I can't do nothing with it
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If the machine was not damaged either by a drop or you trying to root it you can try disconnecting the battery to clear the cache so it gets a clean boot. Here are instructions to disconnecting the battery
Samsung Galaxy Note 8.0 Battery Replacement
if you just disconnect it for 60 sec it will clear the memory and allow a clean boot .Hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 264
1件のコメント
what was done to start the problem ? was it dropped or were you rooting it?
Jimfixer さんによる
