メインコンテンツにスキップ
グーグル5番目のネクサスフォン。2013年10月31日に正式発表され、4.95インチ1080pディスプレイ、2.26GHz Snapdragonプロセッサ、LTEをサポート。Android 4.4.2、KITKATを搭載。製造はLG。
222回答 すべてを表示
締切られた回答
Are those reeeally bad PCB pads recoverable?
So yeah i did a really great job there destroying those pads as you can see in the pictures i posted, anyway is it reparable? i am more worried about the 3 pads in the top row, i don't see any connection to the board there, in the pad in the second row i managed to expose the copper connection, i fell like something can be made, maybe not by me, i did enough damage here.
first photo
second photo
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
zouteline actually that still looks very good. Next time watch your heat a bit better. Most likely you did not get the solder hot enough and the pads stuck to the connector while you pulled it off. The top three will close while you solder the connector back on. The bottom one may require a thin copper wire soldered from the trace to the connector. It should not be very difficult for someone with microsoldering experience to fix this. Fixable? Definitely.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thank you for the good news!
Now i have to find someone to fix this.
さんによる
That will of course depend on where you are located. I'd recommend places like this but there are a lot of them out there. Your call
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 157
