メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony PlayStation 3 Moveは、3D空間で動作するワイヤレスコントローラーです。MoveはPlayStation Eyeカメラとペアリングして使用し、ゲームの世界をプレイヤーに鮮やかに伝えます。修理は簡単で、一般的なドライバーとリペアツールがあれば対応可能です。 モーションコントローラーモデル番号: CECH-ZCM1U。Eyeカメラモデル番号: SLEH-0048。
Why does LED brightness decrease with temperature?
Hi There
I know this isn't about the Move specifically but my curiosity has gotten the better of me, that and the fact I can't find anything using Google.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
5件の回答
ベストアンサー
I'm not an expert, but from what I understand this effect is due to resistance. As I learned in high school physics, there are basically 4 things that effect an objects resistance:
  1. The material (i.e. Copper conducts better than aluminum)
  2. The length (i.e. a 10 foot cable is more resitive than a 2 foot cable)
  3. The cross section (a thick cable is less resitive than a thin one)
  4. The temperature (A hot circuit is more restive, hence cooling fans in computers)
So that would mean that if the LED in the move were to heat up, the system would become more resistive and there would be less voltage turned into light.
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
Excellent insight by Alex Jansen.
さんによる 共有
コメントを追加
It is true.
I did a Chemistry experiment, where we poured Liquid Nitrogen on LEDs and they would get brighter (due to lack of resistance induced by temperature).
Putting LEDs in boiling water made them dimmer.
Obviously neither of those things will (hopefully) not happen to a Move Controller, but thats why it changes in brightness.
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
Dear Collin,
LEDs are made up of semiconductors, then how the resistance of material increased with temperature?
さんによる 共有
コメントを追加
This article offers a good explanation of how LEDs function.
The Cliff's notes version is that "LEDs typically change in brightness and color with temperature. As the temperature rises, the output decreases and the color shifts towards the higher end of the spectrum."
Some of the background as to why it increases increases in brightness: "...There are several factors that can affect the [wavelength]. One of these is temperature. As the ambient temperature rises, so to does the LED wavelength. This increase will typically be from 0.1nm/°C-0.2nm/°C depending on the type of LED used."
As the temperature decreases, so does the LED wavelength, making the LED brighter.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Any diodes have negative temperature coof. Some around 2.1mV/°C.
Output light is a power. If voltage across the LED drops 2.1mV/°C and current is constant - power goes down, light intensity too.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
In the above question
a)constant power supplying to LED, means no variations in power ok.
So In generally materials characteristics effects with temperature.
If Heat increases beyond the particular material properties,resistance increases causing oppose to flow of electrons ---when electrons decreases, Light (Brightness) gets low.
for fun only----LED using in AC Room gets very little effect than non AC room with Temp high.
Sorry i am not good yet english.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Donavan Morris さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 22
今までの合計 17,388
