メインコンテンツにスキップ
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
1049回答 すべてを表示
Are home buttons from 5S interchangeable with SE?
I watched and read the entire iPhone SE breakdown. They mention several parts' interchangeability but did not cover the home button. Are these parts interchangeable? Can I use a 5S home button in an SE and vice-versa? (Please do not add information concerning their functionality after being switched; I am only concerned about fitment)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
ベストアンサー
Kaye's answer was that the home button was not interchangeable, but the link he/she provided said the opposite. It looks like the home buttons are interchangeable, but as with other Touch ID home buttons, will not provide Touch ID functionality. Only the original home button on a Touch ID device will work 100%, but these will still click and perform the other home button functions.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
yes u can iphone se and 5s are compatible its work for me butt u wont have ability to set tuch id
さんによる
コメントを追加
最も参考になった回答
You can look at the APN printed on the cable, they are exactly the same.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thanks, Tom. I don't currently have an iPhone SE at my disposal - did you look at part numbers listed on this site or did you compare part numbers in person with actual examples?
さんによる
Well you can check the teardown pics. On the 5s, the APN is 821-2092-01, while on the SE, it's 821-2092-A. The first seven digits are the same. The difference at the end could indicate different colors or part vendors, but the part itself should be compatible.
さんによる
コメントを追加
Just tried 5S home button on an SE. Yes, it works.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
do not think it worked. this blog you can have a look http://www.etradesupply.com/blog/iphone-...
このアンサーは役に立ちましたか?
スコア -1
3 件のコメント:
According to the link, it does work. Most repair techs know that only the original home button in a Touch ID device can be used for Touch ID - replacement parts only need to have the click functionality, and this does!
さんによる
i‘m sorry, you're right, i mean it still features the click functionality but not the touch id.
さんによる
No worries; thanks for the link!
さんによる
コメントを追加
回答を追加する
Ryan Alexander さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 35
今までの合計 7,063
