メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
BlackBerry Passport SQW100-1は、物理キーボードとタッチスクリーン機能を1つに統合したスマートフォンです。正方形に近い独特の形状が、他のBlackBerry端末と一線を画しています。
submerged in water at least 30 minutes
I dropped my phone in water it was submerged at least 30 min. I have had it in dry rice for a week. I plugged in to charge and the red light is on and has not changed for several hours . Is the phone repairable?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
rtiist4you sorry to tell you but the rice is not working. Rice is the absolute wrong thing to do. One might as well not do anything. So start by cleaning your board and your connectors asap. You will get corrosion damage if you do not fix that properly. The very first step I would take is to disassemble your phone. Then take a careful and close look at all components and connectors. Truly assess the damage. Look for corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. Remove all the EMI shields. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for a Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. The importance here is the cleaning. You can also dry the board at ~220F in an oven for a couple of hours after the cleaning. If you can get it professionally cleaned in an ultrasonic cleaner, then that is of course the best way to go. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now.
Keep in mind that water damage is the hardest to troubleshoot and to repair. Whatever you do stay away from RICE
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
rtiist4you さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 15
今までの合計 1,131
