メインコンテンツにスキップ
The Dodge Dakota (called the Ram Dakota for its final two years of production) is a mid-size pickup truck from Chrysler’s Ram division (formerly called the Dodge Truck division). The second-generation Dakota began development in 1991, though they were not introduced until 1996 for the 1997 model year.
71回答 すべてを表示
Do brakes and wheel bearings need to be changed at same time?
The mechanic says that front brakes and wheel bearings need to be replaced on my 2002 Dodge Dakota. There is some pulsating sometimes when braking and can feel the brakes skip on a hard stop. Are the wheel bearings a part of the braking system or separate component? Is it better to replace the bearings while having the brakes worked on ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
to the person that answered my question thanks. I just bought the used truck so if anyone caused the warped rotor his driving was the issue. thank you
さんによる
コメントを追加
3件の回答
ベストアンサー
I agree. I'd also stay away from the "mechanic" who told you this.
I would have somebody else check the rotor runout. It's a simple thing and will confirm the reason for the pulsating. Who knows, maybe you do need wheel bearings, but it's pretty unusual, and warped rotors are pretty common. If they are warped, replace them, don't have them resurfaced. They are not expensive. You'll have to replace the brake pad too. Why did this happen? Maybe you are one of those drivers who keeps their foot on the brake while they drive, overheating the rotors and ruining your gas mileage too??
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
No. Your rotors are warped and that is the pusating that you are feeling when braking.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Your revolution is over. Condolences. The bums lost. My advice is to do what your parents did; get a job, sir. The bums will always lose. Do you hear me? The bums will always lose!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
kai さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 36
今までの合計 4,408
