メインコンテンツにスキップ
Improved second generation Google-branded tablet with a 7" screen.
98回答 すべてを表示
[Fixed] Tablet constantly reboots, even after factory reset
Greetings,
I recently got a Nexus 7 2nd gen to repair and it is constantly rebooting and the power button wasn't working. I changed the power and volume buttons strip, and now the button does work, but the tablet still reboots. Here is the troubleshooting I did so far:
- Looked for any damage or dirt on the motherboard (there isn't)
- Unplugged and plugged back the battery
- Tried a factory reset via unlocking
- Re-flashed the boot loader
The tablet reboots about every 8 seconds, so it looks like the power button is stuck, but physically, it isn't. If I press repeatedly on the button, the tablet boots all the way to Android. If I stop, the tablet reboots after 8 seconds.
I need to know if I'm missing something before looking for a replacement motherboard.
Thank you in advance
EDIT: I finally went and bought a replacement motherboard (It is quite cheap and fits within the repair budget), and everything is running smoothly.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
have you tried booting with the power flex unplugged?
さんによる
I didn't try that, but as far as I know, these devices won't start if there isn't a battery, or enough charge in it, even if it's plugged to a charger.
さんによる
No, I mean the flex cable with the power buttons unplugged, but battery in. You can probably still sell the motherboard on ebay for a bit if it is just a bad fpc connector.
さんによる
コメントを追加
1 件の回答
ベストアンサー
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Marx さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 4
過去 30 日: 6
今までの合計 305
