メインコンテンツにスキップ
Anyone know how to replace the screen on the Mediapad M2 8.0?
Hey People.
Having some trouble with my Mediapad M2. The screen went black. Eventho it still responds to touch (I can hear my screen unlock and i can dial and stuff) but the screen stays black. Im hoping its a connector thats come loose..
But seeing the thing has only 1 tiny screw, i have NO idea how to open it up to check for problems.
Cant find any on the internet. So does anyone have an idea on how to open it up?
Thanks a bunch
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Most likely it's the flex cable. Lcd is double sided taped to lcd bezel. Bezel is snap connected to chassis. Parts are cheap enough I would order lcd/digitizer assy and flex cable. Replace flex and if that doesn't fix then lcd assy. Be careful with flex cable install. It has design flaw where it will rub against micro sd casing and sratches off the runs/traces of the flex cable, resulting in the problem you're having now. If you need more help repost in xda forum and I'll post pics.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
hi friend
you can see best video in below link.
https://www.youtube.com/watch?v=suLeqrVG...
best regards
noroozi
caspiangoldenkey.com
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Maurice さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 2,334
