メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
締切られた回答
Why is my iPhone screen black? Logicboard
So I've tried replacing the screen on my iphone 5 a few times and while the operation itself is now a breeze, I'm no closer to a solution persay. Looking closely I can see that there now are a few pins missing/broken off on one of the connectors, which is entirely my fault. Now, I will assume that's the reason for it not working. The last screen before this didn't work either. The iphone is recognized on my laptop in itunes and I can hear voice over off/on . It's just the display that's unresponsive. Still, my simcard isn't recognized anymore (it did previously). Now, if I replace the logic board both of these issues could clear up yes?
When I insert my simcard (it works fine in my iphone 6) it says in itunes :
There's no valid simcard in the iphone you're trying to activate. Or something like that.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
For what you say I would say that the issue comes from the logicboard because there is more than one system that is failing: LCD and Sim Card.
Do you have any spare iPhone 5 where you can test the simcard/LCD? - That would be a good start; but for what you say, my first thought is: logicboard.
Let us know how it goes!
P.S: logicboards are not cheap, I've seen some for under $100.00
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Oh, I know that already. Say, apart from ifixit's part store, do you know of any online shop selling iphone 5 logicboards? (I recently got a picture instead of just a black screen that lasted for roughly...5 seconds?, on it, but..I tried rubbing some alcohol on it (the disinfectant kind). Maybe I should do that again...
I have also seen those pin connectors cheap, but I have no confidence in my soldering skills and I've never done it before. Seems to me that it's a better way to replace the logic board rather than to mess up something as small as those connectors. I mean, all I have to do is go on to youtube and find some walkthrough of the process.
And, no. I only have one iPhone 5 and one iPhone 6. Previous owner of the iPhone 5 did say it had fallen into a glass of beer/liquid, so...still, when I replaced the screen for the first time (I've bought more than one screen by now) I had no problem with audio, video/picture etc, just...flickering ghost horizontal lines.
さんによる
コメントを追加
I was a complete moron. All I had to do was turn off the sim pin. Now. The screen issue is almost fixed. Except for parts of the screen is darker. Particularly in the top right. Any ideas? No, it's probably not an OEM part but..
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 5
今までの合計 125
