White Cloud on the LCD Panel
Hi
It seems that due to cleaning the LCD Screen with Wet Cloth, the screen is clouded completely.
I showed it to Sony Service Center, but the Technician told me , it is not possible to get it repaired as the LCD Panel will not be available now.
Please see the attached video link to understand what kind of issue is this ?
Note: I can feel the bubbles on the Screen but they are hard and are not removing using pressure technique.
Thanks in advance !
この質問は役に立ちましたか?
3 件のコメント
What did you use to clean the screens?
oldturkey03 さんによる
Dear Oldturkey
The problem is that I am not sure where would i get this LCD panel now ? and What would be the cost of it ?
If not JVC, can we replace with any other TV LCD Panel ??
Amd last question: is this worth to repair the panel OR shoudl i buy a new cheap lcd ? I learned that the 32 inch LED are available at 250 $ range ...
Please suggest !
Thank you for your expert comments...
Yasir さんによる
Yasir a new panel is most likely going to cost you more than a new TV. You can look around and see if you find a broken tV (other than the panel) and then harvest it from there. If you cannot find one you might as well purchase a new TV
oldturkey03 さんによる
