メインコンテンツにスキップ
The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
Where is the fuel filter?
location of fuel filter?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
gas or diesel ?
さんによる
Thanks for the help.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Depending on the year of the truck if its gas or diesel there are several locations . On the diesel its located next to the master brake cylinder. On older gas models its mounted on top of the fuel tank next to the sender unit on some of the newer models its mounted to the frame rail next to the fuel tank . Easiest way to find it is to start at the fuel tank sender unit and follow the fuel lines to the engine. you'll find it in there somewhere. If your not seeing it odds are its one of the ones mounted on top of the fuel tank. Hope this helps
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
回答を追加する
Terry さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 29
過去 30 日: 135
今までの合計 27,175
