メインコンテンツにスキップ
Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
110回答 すべてを表示
How to get rid of the colour seeping across my phone screen?
It used to be a small spot in the top left corner
I had a green and blue patch at the corner of my phone screen. The colour only shows when the screen is on (the brighter the screen the more visible the colour) and the abnormale colouring did not show up in any screenshots. It looks like water so I put it in rice for a few days. When I took it out it had only gotten worst. The colour has now seeped across the screen and limits visibility. What should I do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
3 件のコメント
Did the phone actually get wet before the issue started?
さんによる
It may have gotten wet from humidity but it was never in water
さんによる
yup. broken LCD as it is evidenced by the appearance on the right hand top corner. Replace it to repair your display.
さんによる
コメントを追加
3件の回答
最も参考になった回答
@angelblais without actually seeing your screen and only going by your description, it sounds like a broken LCD. You most likely will have to replace it. Here is the guide for that. Of course, to verify this you can post some images of what your screen looks like with your original question. For that use this guide
iFixitの画像
ガイド
iFixitでの質問に画像を追加する方法
難易度:
とても簡単
2 - 5 minutes
OnePlus One Display Assemblyの画像
ガイド
OnePlus One Display Assembly Replacement
難易度:
中レベル
45 minutes
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
You may have dropped it recently and it didn't break on the outside bit leaked on the inside
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I got only blue,black , violent shade on my phone corner
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Angel blais さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 20
過去 30 日: 85
今までの合計 23,496
