Mouse clicking
Trackpad mouse click doesn't work any more, but bluetooth mouse does.
First, remove the upper case (a reasonably easy undertaking with the guide) and check the really thin cable coming from the trackpad button to the upper case ribbon. Is that connector properly connected?
If so, it looks like you need a replacement upper case, as the trackpad is permanently attached to the upper case.
Good luck!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 5
今までの合計 1,117
1件のコメント
Can you physically click the mouse?
rab777hp さんによる
